Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Solid Textures tricks
5 REPLIES 5
Chponks
469 Views, 5 Replies
Hi!
There is a problem with texture mapping.
I have an Original Object with aligned texture projection.
Also I have numerous copies of the Object.
How can I apply Object's texture projection to all copies?
(see attached file)
Or can I do it with "Convert Solid Texture" only?...
Best Regards
5 REPLIES 5
q_vazk
in reply to: Chponks
Group texture placement node under object and maybe try to duplicate them together?
anand_joshi
Hi Friends,
No grouping necessary.
When you apply a shader with projection texture, make texture visible. Now if you just do copy & paste, the texture node is also copied and pasted along with the object.
Try it.
Regards
Anand
Chponks
Hi! Friends, thanks a lot for your replies!
But I have a comment:
How do you copy texture projection? (Multi-lister>edit>copy)?
When I copy a texture projection, shader is also copied. It's not a problem, if I have two or three copies. But in case with 50 object's copies, shader will be copied also 50 times. (image with bottles - here I used "convert to smear")
PS. I've tried to use "link with object" in "3d placement" tools, but it doesn't work in this case... (image with spheres - projections are copied to the instances, but doesn't take effect)
best regards, pozdeev
digiformer
hmm this is indeed a problem.
Just in case you do have something easy to texture like the bottles label, I suggest you forget the projektion and put a fitting texture right onto the surface. Maybe via layered shaders. Just like you would label the bottle with a real sheet of paper. Then the copy thing will be no problem.
...tobias
Dua-Xiong
If you have a fairly simple set of surfaces to duplicate, Solid Textures is probably the simplest solution. Edited by: Dua Xiong on Oct 1, 2008 2:11 AM
