Hi Worfsonofmogh,
Thanks for u r comment.
The purpose of rendering lamp is check the styling appearance before we go for RPT.
So if i use bump maps, the results wont be precise.
I actualy tried in showcase by increasing the raytrace value above 5, only then i m able to acheive the desired result.
But the too much of raytrace or resulting in collage like reflections in other areas like extension and low beam \ high beam reflector.
Becoz of this too much reflections, we are not able to see the reflector step pattern.
Looking forward for u r reply.
with regard's
Karthick. P
Thanks and Regard's
Karthick. P
