Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Project Falcon Technology Preview now available on Autodesk Labs
63 REPLIES 63
Message 1 of 64
scott.sheppard
4061 Views, 63 Replies
Project Falcon for Autodesk® Alias software is a wind tunnel simulator that seamlessly integrates with Alias allowing designers to interactively investigate the aerodynamic performance of their designs at any stage. Industrial designers can get intuitive simulation results for their designs in seconds with no specialist knowledge required. Simply launch Project Falcon and results appear immediately. Project Falcon makes use of a revolutionary new automatic meshing technology that can handle any geometry at any stage of design. Flow and wind pressure results update almost in real-time in response to changes in wind-direction and speed. These results can be used to improve design decision making much earlier in the process.
Understanding the aerodynamic behaviour of your design is critical whenever air flows over, around, or through a design. As “organic” surfacing becomes more prevalent in industrial design, so too does the opportunity to create designs that work in harmony with the wind to reduce costly aerodynamic drag.
http://labs.autodesk.com/utilities/falcon/
Please try it and post your comments as a reply in this thread.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
63 REPLIES 63
Message 61 of 64
hartogj
in reply to: hartogj
Thanks for sharing your thoughts Claud. Falcon is actually solving the full N-S equations using the Finite Volume Method. A bit more info is available in the validation doc on the main labs page.
We have received other requests for lift measures in addition to drag and are looking at it. Just curious about your question on moments. Would those be about the model origin, an axis specified by the user, or the aero center? Probably more than we would offer in a labs release but we are interested in knowing what would be helpful.
Autodesk Simulation 360 includes Simulation CFD, which is a commercially available CFD code fit for users who are looking for more detail (moments, turb model options, run comparisons, etc) than we can provide in this Falcon labs release:
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=19730839
Jon den Hartog
Product Manager
Message 62 of 64
Thanks for responding. I strongly encourage your team to get Cl (or Cz) and Moment Cm calculations included since the efficiency of a design can be better evaluated. These are just reference useful Falcon application as it is intented. For exact evaluations for science and engineering one should look at the other CFD offerings as you mention.
The question of where the moment should be calculated is a great one. As long as there is a reference to the body size is OK. For practical purposes historically the airfoils are referred to the 25% chord and is a good one to use. I believe that, if you clariify that as a DEFAULT you are calculating at 25% LENGTH you are going to be fine, except for roll axis (X) or longitudinal (along the length axis) which should be centered to the symetry selected by designeer. Additionally, you could give the designer the choice of axes positions. The problem of calculating moments at the center of pressure (which is always moving) is more complicated for further analysis and unnecesarily so. It is also less effective at quickly recognizing variations in design... following the intent of the Falcon initiative.
Message 63 of 64
hartogj
Thanks for the thoughtful response Claud. Have a much better idea of where you're coming from now.
Jon den Hartog
Product Manager
Message 64 of 64
Discussion_Admin
Hi all,
Project Falcon now has it's own hangout over in the Autodesk Labs!
Please continue to post your questions and thoughts over there in the new Project Falcon forum!
Discussion_Admin
Direct link
http://forums.autodesk.com/t5/Project-Falcon/bd-p/Falcon
