Alias General Discussion
Board Manager
scott.sheppard
Message 21 of 64 (627 Views)
Re: Project Falcon Technology Preview now available on Autodesk Labs
02-09-2012 08:35 AM in reply to: ABukowski
I have been meaning to reply back. Thanks for the conformation that updating your video driver fixed the issue.
Scott Sheppard
Program Manager
Autodesk Labs
Active Member
ABukowski
Message 22 of 64 (573 Views)
03-12-2012 05:32 AM in reply to: scott.sheppard
I've got some issues with Falcon's ability to calculate drag correctly, or it's interpretation of model data and drag.
I can replicate expected figures at low speeds for primitive shapes, but if i place an elongated shape such as a rectangle into Falcon it seems to calculate some areas incorrectly.
For example, I run a test on a very basic rectangle shape with a curved leading edge.  This gets calculated as having a CD of 0.7 with a drag force of 2947 N.
The frontal area of the model is 8.925m, but to have the CD and drag being calculated as it is would require a frontal area of around 11.11m, or an air density of 1.5kg/m3, both of which are incorrect.
Similarly, if the model is rotated before import to requre a 0 degree yaw in Falcon, there are errors in the calculation once again.
Is it possible to divulge some more information regarding how Falcon interprets the geometry model and the airflow / drag readings so that this issue can be troubleshooted?
Board Manager
scott.sheppard
Message 23 of 64 (561 Views)
03-13-2012 06:37 AM in reply to: ABukowski
Please send me your file, so I team can play with it, and we can be sure we are seeing the same results.
Scott Sheppard
Program Manager
Autodesk Labs
Board Manager
scott.sheppard
Message 24 of 64 (532 Views)
03-27-2012 08:03 AM in reply to: scott.sheppard
The team has shared with me that the next release will have accurate (error < 0.001%) front area calculated.
Scott Sheppard
Program Manager
Autodesk Labs
Active Member
ABukowski
Message 25 of 64 (525 Views)
03-29-2012 03:04 AM in reply to: scott.sheppard
Thanks to the team for looking at that problem.  Looking forward to the next version; any idea when the next update might be expected?
Board Manager
scott.sheppard
Message 26 of 64 (517 Views)
03-29-2012 07:37 AM in reply to: ABukowski
Not sure - I rarely know in advance. Labs is an agile organization that responds quickly, so we don't require advance notice.
Scott Sheppard
Program Manager
Autodesk Labs
Active Member
ABukowski
Message 27 of 64 (513 Views)
03-29-2012 07:47 AM in reply to: scott.sheppard
I'll just check back regularly then.  Looking forward to it!
New Member
katylyn
Message 28 of 64 (487 Views)
04-16-2012 10:13 PM in reply to: scott.sheppard
Thanks for the tips. It can help me a lot. :smileyhappy:
New Member
simon.watt
Message 29 of 64 (467 Views)
04-27-2012 07:54 AM in reply to: scott.sheppard
Install Standalone
Falcon32bit.exe
2011.0.1.0
Project Falcon 2012
on
Windows XP Pro
Version 2002
SP 3
Pentium 4 3.00GHz
2GB RAM
After installation, attempt to run by clicking installed icon... Get the following error
Falcon Application
Exception caught whilst running WindTunnelApp: 'pack://application:,,,/WPFOpenTK;Component/Themes/ExpanderTemplate.xaml' value cannot be assigned to property 'Source' of object 'System.Windows,ResourceDictionary'. Could not load file or assembly 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file
specified. Error at object 'System.Windows.ResourceDirectory' in markup file 'WindTunnel_CFD;component/mainwindow.xaml'.
Subsequently have to kill WindTunnelApp.exe in the Windows Task Manager.
Any suggestions?
Cheers, Simon
Active Member
ABukowski
Message 30 of 64 (417 Views)
06-20-2012 01:59 AM in reply to: scott.sheppard
Is there any word on a likely release of the next update to Falcon?
