Show only
Search instead for
I m facing a typical problem in alias. Whenever i select a object and try to move them, i m supposed to click on the empty space in work area and drag the mouse button if i do so Wat happens is the object which i move just come and stick to the place where i click the mouse and drag. this happens when i scale and rotate . Hope u guys can understand my problem. Generally the object were ever we click our mouse and drag the object moves from its position towards the desired axis, here after my click the objects relocates to the clicked region and then moves along the desired axis. how to overcome this problem.
On the right side of your history line there are three icons that look like red magnets. Make sure that none are selected. They are for curve snapping, grid snapping, etc.
I checked them but there is no snap.
while i transform wat happens is the values getting changed in the bar above as delta (--------------,---------------,------------)
