I am just rebuild an iPhone 6 body and put down the lines and corner curves to use my rail to with
annoyingly I run into this issue now when I want to cap the front face.
genertion curves and rail curves are all made by hand and I cannot figure out where a hole should be
or if lines are not 2D.
I have the file attached if you want to take a look at it.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Solved by TheHangman. Go to Solution.
Here is a different approach, I made draft side faces, the blend surfaces and planar command still failed
but when I lofted left and right edge and then moved the CVs up down left and right to make the face bigger trimming worked.
so when trim works then obviously edges and surfaces are plana. so why did the planar in the first step not work?
Claas Kuhnen
Are you looking for something like this ? The back planar surface ?
Hey cekuhnen
The simple solution Align surfaces... how I came across this video here that may assist you onwards 09:15 here shows a very good technique worth learn his principles and apply it on your design.
https://www.youtube.com/watch?v=0PwCxwy37Sc
Hope it helps, Happy modelling
if this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Claas Kuhnen
The Set Planar tool can be quite finicky. It sometimes will just not want to cooperate; don't waste your time trying to make it work.
Just build a 1x1 Plane and cut it manually.
Claas Kuhnen
Yes, it has been like that for a long time. They made some changes to it recently and it is now MUCH better, but I still find that sometimes it just doesn't want to work where it really should have no problems.
