I have just noticed that when switching to perspective view, sketching CV curves based on Top, Bottom, Front, Back, Left & Right view is quite troublesome, and the curve will not bend normally as in Orthographic and Perspective with Ortho Faces view. Is this something normal in Alias ? Please help.
Solved by duaxiong. Go to Solution.
I am not sure if I completely understand what you are saying, but perhaps it has something to do with the fact that when you create or edit curves in the Persp View you are moving them in 3D space vs an Ortho view in 2D. It is normal that the interaction will be quite different.
