Hi everyone,
I've tried for the past hours to resolve this problem but with no success. I turn to this forum in hopes of finding a solution!
I have a closed box for example made up of 6 skins for surfaces, but once I put a light inside, to project light out of the holes I made on the top side surface, there is light leaking from the corners of the box, along with strange shadowing on the actual skin!
The surfaces are aligned, they are not transparent. What do I do? Do you suggest I use a certain type of light to create my desired lighting effect?
