Hi, i have an ssd C disk to boot windows and another E drive for programs when i change the drive letter to E it still wants to install on C drive how do i change so it installs everything on E drive?
Solved by TheHangman. Go to Solution.
I have exactly the same setup as you. 1 SSD + 1 HD.
I can install without any problem in any of them. You get a problem when you click browse, to select a folder in E drive?
Will not accept it?....That would be very weird. Make sure you are not doing anything wrong. Execute install as ADMIN?
It should all work like you are expecting, is all I can say.
Sorry for not being able to help a lot more, i cannot see where a problem could be honestly. It should be the breeze you are thinking of.
Hi ZNUZ
I guess it happening because you are imputting it into the x86. I guess it says everything, x86 doesn't support Alias 2015, this version wont accept it. indicate it to x64 any where and happy modelling and should work just fine.
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
nice one happy modelling!
