Hi!
I'm having problem to load and save my user preferences set. I get an error "Text operation failed. Check errorlog" and this is what I get in my errorlog:
"Scheme error in file 'c:\program files\autodesk\alias2012\Scheme\Comlib\al_special.scm' on line '795'
Attempt to create existing choice symbol NULL->NULL->Show/hide linked masks in lister( FilterMasksInLister )
Invalid font file ."
Does anyone know how to fix this problem? 😞
I am also facing similar issue while loading/unloading a plugin in Alias 2014/2013 on specific machine.
Below is the error log.
Scheme error in file 'c:\program files\autodesk\alias2014\Scheme\Comlib\al_special.scm' on line '884'
RegQueryValue STUDIODOCS_INSTALL_LOCATION The system cannot find the file specified.
Can anyone pls help.
Srinivas
Never seen such error before.
Try this:
Delete all your startup preferences. The actual files.
Start alias, and it should create a new set for you.
Maybe it helps.
