this is really sad to ask but the manual does not explain what is going on:
I cannot make the skin / loft tool work right.
1. I cannot select more than 2 curves to loft
2. I get a lot of distrotions
All I want is to loft / skin those rings and I am sure it worked before!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Both skin tools work fine here.
Remeber to press SHIFT when skinning more than 2 curves. It will keep skinning untill you like.
OMG you just let go of shift once and it is done!
Claas Kuhnen
Sorry to bring up an old thread, but is it possible to remove the "P" markings when using the skin tool?
When I press F12 to see the model without any of the edge lines (or whatever they're called), everything disappears except for these ugly green lines.
Sure!
P T or C just delet locators.
Hope it helps, happy modelling.
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi dchang.id,
Positional Continuity – Only check for gaps between surfaces (labeled with “P” symbols).
Tangent Continuity – Check for gaps and tangent discontinuities (labeled with “T” symbols).
Curvature Continuity – Check for gaps, tangent, and curvature discontinuities (labeled with “C” symbols)
Refer to this webpage: PTC
