Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Help: the shadow doesn't work....
3 REPLIES 3
peterpeterMO
287 Views, 3 Replies
Hi, all.
I just start using alias 2008 instead of 13.5 version.
And now the problem is when I click either hardware shader or any diagnostic shader, no shader shows up.
However, when I use direct render or render, it works fine...
So I wonder what could be the reason....
and btw, I m using XP SP3, and graphic card is Geforce 6800 Series GPU...
don't know if it has anything to do with it...
Thanks!!!!!!!!!!!
3 REPLIES 3
mratliff
in reply to: peterpeterMO
Hi Peter,
Unfortunately, the Geforce card as well as SP3 is not supported.
--Matt
Autodesk Industrial Design Support Team
pulkepop
Hi Matt. I had the same problems. I'm starting to use AliasStudio and now I need a new machine. I'm on a low budget, so I just wanted to know if there's a gaming gpu that works well with AliasStudio even if it's not supported. Thanx.
anand_joshi
I guess, nvidia quadro cards are also getting cheaper & cheaper now a days.
Good luck !
Regards
Anand
