Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
helix shape
2 REPLIES 2
350 Views, 2 Replies
helix shape
Does somebody knows how to make a helix shape? i need to make a helix out of a shaped like rectangle like to twist it and make it look like a helix
2 REPLIES 2
ravenzep
in reply to: 918398
Yes there is, and for your needs it s pretty handy.
The way to do it in alias is through the RAIL surface tool.
Imagine a long rectangular strip, say 100cm long by 10 cm wide. Let s model this basic slab (surface) with the rail tool.
I suppose you can do that. Now on the rail tool options, there s a otion called Rotate Xform. Type say, 1500 in there. There u go, if you want to have say, a helix curve, you can duplicate one edge of that helix surface and you get the curve. Now you can extrude any shape you need along that helix path.
Good luck!
in reply to: 918398
THANKS!!!!!!
