Alias General Discussion
Active Member
sgeggie
Message 1 of 2 (294 Views)
Getting layer status in Alias API
294 Views, 1 Replies
04-11-2013 04:31 AM
I'm using the Alias API to retrieve model data from .wire files. I have a file here with two layers, the empty default layer and another layer, "what", which contains geometry. "what" is set to be invisible, but is currently selected in Alias.
Using the API, I can detect that "what" is invisible with the AlLayer::invisible() method. However, the AlLayer::isPicked() method always returns false. So even though the geometry is visible in Alias (due to its layer being selected), I cannot detect this with the API. I have attached the file.
Is there some other way to detect that this geometry is currently visible in Alias, despite having a layer with "invisible" status?
Thanks in advance.
The solution was to use AlUniverse::creationLayer() rather than isPicked.
Active Member
sgeggie
Message 2 of 2 (242 Views)
Re: Getting layer status in Alias API
06-25-2013 01:46 AM in reply to: sgeggie
