Alias General Discussion
Valued Mentor
ravenzep
Message 1 of 9 (212 Views)
F.A.O. Autodesk
212 Views, 8 Replies
04-13-2012 07:25 AM
Just found 2 bugs on the new 2013 release:
1- Translators are not working. Colossal translator error. You cannot save a file or export it as IGES, for example.
2- Picking stuff.... It s a mess! Either you swapped left and middle mouse buttons, or add and toggle to selections are swapped.
Hard to justify!
By the way, Showcase 2013 cannot open any single file other than native showcase format.
Hope we are not getting a pattern here.
Anyway, i felt I should report what i have encountered in case nobody has noticed yet, so it can be fixed. Thank you.
I wanted to beta test this software at due course, but it was a mess to be enrolled in the program, so unfortunately i did not join and i did qualify for it.
Best regards!
Valued Contributor
JohnDixon8251
Message 2 of 9 (209 Views)
Re: F.A.O. Autodesk
04-13-2012 10:49 AM in reply to: ravenzep
I am not having any issues exporting iges.
Valued Mentor
ravenzep
Message 3 of 9 (205 Views)
Re: F.A.O. Autodesk
04-13-2012 02:35 PM in reply to: JohnDixon8251
Weird.... Here is a no go!
Check your selection options.... Is it working as it should?...Here i have left and middle mouse buttons switched.
Thankx for feedback:smileyhappy:
Valued Contributor
JohnDixon8251
Message 4 of 9 (203 Views)
Re: F.A.O. Autodesk
04-13-2012 06:23 PM in reply to: ravenzep
I don't use the different buttons, only the left, but it works normally. It will pick and unpick. The middle button only picks and the right button only unpicks.
Valued Mentor
ravenzep
Message 5 of 9 (199 Views)
Re: F.A.O. Autodesk
04-14-2012 08:19 AM in reply to: ravenzep
The normal way, left button picks, right unpicks, and middle toggles! :smileyhappy:
Anyway, each person has his own taste, of course.
Thanks for your time and input:smileyhappy:
Valued Contributor
JohnDixon8251
Message 6 of 9 (197 Views)
Re: F.A.O. Autodesk
04-14-2012 06:16 PM in reply to: ravenzep
Strange, I have always used only the left button to pick/unpick.
There is a option window under "Preferences" called "Selection Options" where you can set the buttons how you like them.
Valued Mentor
ravenzep
Message 7 of 9 (171 Views)
Re: F.A.O. Autodesk
04-19-2012 03:19 PM in reply to: JohnDixon8251
Did you read the very first post?.LOL :smileywink:
Valued Contributor
JohnDixon8251
Message 8 of 9 (168 Views)
Re: F.A.O. Autodesk
04-19-2012 03:30 PM in reply to: ravenzep
Not sure what you are refering to, I must be missing something.
Distinguished Contributor
donest
Message 9 of 9 (130 Views)
Re: F.A.O. Autodesk
05-18-2012 04:49 AM in reply to: ravenzep
Picking and unpicking works fine for me. Iges export works fine too. Just letting you know, so you don't think there's a bug. Rapidly picking and unpicking using a pick box (marquee) sometimes doesn't work well.
