Hi Guys,
Can somebody explain me the diff between CV cur and EP curv. Generally i use CV curv only.
I came across a Autodesk tutorial, in that they were using EP curv. Now i would like to know y and were we should use these two Tools. Wat is there + and -.
Pls explain me.
Karthick. P
Hi Karthick,
In basic terms, an edit point curve is a convenient way to make a curve between 2 other curves or surfaces.
You just snap an edit point to each curve or surface and you get a straight line between them. You can then manipulate the curve by moving the CV's as you would any other curve. It is a simple way to lay down single span curves. Of course you can use the control panel to increase the number of spans or to change the degree of the curve after you have created it.
You can make freeform curves using an edit point curve but it is fairly uncontrollable.
Just remember that the curves created, by either tool, are identical curves. You're just using a different method to create them.
