Alias General Discussion
New Member
b55507
Message 1 of 7 (2,804 Views)
Diagnostic Shading section is gone!!!!!!!!!!!!!!!!(Alias 2013)
2804 Views, 6 Replies
05-13-2012 06:06 AM
I closed it accidently. But I Don't know where can i find it.....
Please Help me!!! I got tones of asignments!!!!
Valued Mentor
ravenzep
Message 2 of 7 (2,796 Views)
Re: Diagnostic Shading section is gone!!!!!!!!!!!!!!!!(Alias 2013)
05-14-2012 10:01 AM in reply to: b55507
Object Display/Diagnostic shade.
BYE
New Member
t.j.obrien20
Message 3 of 7 (2,790 Views)
05-14-2012 06:11 PM in reply to: b55507
yeah i had the same problem, kindof an inconveniance, i even tried to unistall and reinstal but it didnt work either. please help autodesk.. WHERE IS THE DIAGNOSTIC SHADING palette????
Active Contributor
KevinDeSmet
Message 4 of 7 (2,783 Views)
05-15-2012 10:20 AM in reply to: b55507
Try choosing a different workflow under Preferences > Workflows?
Some do not have the diagnostic shade in the control panel.
Active Contributor
KevinDeSmet
Message 5 of 7 (2,780 Views)
05-15-2012 10:22 AM in reply to: b55507
Also, irregardless of that, top right there is a drop-down that also controls this. It should be on "Default".
New Member
jaker277
Message 6 of 7 (2,060 Views)
04-25-2013 04:56 PM in reply to: KevinDeSmet
In 2013 toggling to 'default' no longer briings up shaders and visual states docked inside the 'Control Panel'.  Anyways, toggling over to default every time I want to shade would be a pain...
However, one can now middle mouse drag a shader into their pallete or shelf.  So pull down 'Object Display' > 'Diagnostic Shading...'.  When that window opens you can mmb drag the shader to wherever you like, even your 'Marking Menu'.
If you can't see the 'Diagnostic Shading...' make sure you have long menus truned on,  Preferences> Menus> Long Menus
A little on this, you can also customize the settings and create different ones.
http://wikihelp.autodesk.com/Alias/enu/2013/Help/0124-Autodesk124/0174-Interfac174/0260-Customiz260/...
When you are done close out the "Diagnostic Shading...' window for a clutter free workspace.
florar23
Message 7 of 7 (1,997 Views)
05-09-2013 04:32 AM in reply to: jaker277
Since Alias 2013 my Control panes at all was away. I have to click it manually on Windows Control Panel and it isnt aligned any more on the main screen.
