Alias General Discussion
Valued Contributor
JohnDixon8251
Message 11 of 13 (132 Views)
Re: Curve Snap tolerance issue - does not really snap onto curve but next to it
10-02-2012 03:51 PM in reply to: cekuhnen
That is correct, what you are doing is fine. And, interestingly enough, your screen shot is now appearing in the first post.
Valued Mentor
ravenzep
Message 12 of 13 (125 Views)
10-24-2012 02:09 AM in reply to: JohnDixon8251
SET DRAW PRECISION to something like 0.85.
That should do it, or you have a gfx hardware issue.
nicolas.caquelin
Message 13 of 13 (86 Views)
02-26-2013 01:12 PM in reply to: ravenzep
I think also about the Draw Precision value issue, by default Quality Draw Precision = 0.5
This is too low if you are working in Class A with a single span surfaces / curves, as the previous post said try to increase the value if your computer works.
But take care about the value, if you check the maximum is 1 but after many investigations please remind about the "exponentiel" value from 0 to 1, also if you put 1 the most of the time 90% it works well... But sometime you will feel your model move slowly and block looks too big ! ! ! My recommendation is to put maximum 0.9 for a nice result.
Nicolas Caquelin
