Again I am having trouble creating closed surfaces using the extrude tool.
Please check the accompanying pictures....
Ok I have:
- created single curves and lines, connected them and extruded them.
- created single curves and lines, then aligned them tangential using the new align tool, and extruded them.
- created single curves and lines, then aligned (as above), connected them, closed them using the close tool, and extruded the resulting curve.
I always check the direction of the curves to make sure ends meet starting...
Any how I try to create the surfaces I always end up with the red arrows indicating the surface is not closed. (I believe...)
Same counts for the front and back caps if created, they somehow do not match to a degree a good shell can be created from them. (either caps or a single trimmed surface, created by the planar tool) Again I always check the directions from the normals to make sure all are pointing outwards...
My goal is to create a guitar-neck shell and subtract it from a guitar-body shell in order to create a pocket in which the guitar-neck fits perfectly. This is doable, however I must always fool around with the precision (in the Construction Options) or mess with all possible ways to create the initial geometry, because after the pocket is created I must round all edges, varying from say 2,0 mm to 12,5 mm ... and things get really messed up if all is not geometrically correct..
So, my question would be:
How does one create a shape out of multiple curves, lines, etc. making sure the result is closed (and/or to what degree)... At least close enough to stitch to a good shell being able to do the boolean subtract thing without problems (message: there are gaps on both shells so no way Jose)
Oh yeah,
grabbing the chance to whish all here a very happy new year!!!!
Cheers!
Hans
