Hi guys,
I am trying to get an object in Alias to change from a red to a blue then to a green - how do I do this using animation?
Please help -
Thanks in advance.
Manish
quite a time passed since you asked this. Did you find the solution or do you still need some hint?
Hi Digiformer,
Anything would be highly appreciated. I have struggled quite a a bit and cannot seem to find the method.
Many thanks in advanced -
Manish
You first have to activate the shader animation parameters in the parameter controls (see screenshot).
After you did this, everything will be easy.
set a color, set keyframe, set other color, set new keyframe...
See the attached wire, too.
Cut the jpg extension. I put it there due to the "whimsical" forum file format restrictions. Though Alias should still recognize it as wire file.
Kind Regards
Tobias
Hi Tobais,
Many thanks for your prompt reply with help!
I can't seem to download the wire.jpeg file - can you email this to me?
Cheers -
Manish
sure i could email the file...though it bugs me...there must be a way to provide a wire file in an Alias Help Forum
Lets try a zip file...
Hey thanks for this. I will try what you have suggested and will let you know how I got on!
Many thanks - Manish
I managed to activate the shader animation parameters and setting a colour, setting a key frame...etc...
After opening your file, I noticed that you have 1 shader for 1 object and that it changes colour gradually within its paramteres - how have you done this?
sorry I did not quite understand, what exactly is your question now...
Did you get the color animated meanwhile?
If not, where did you get stuck?
The shader animation is not chained to an object or something. You can animate shaders with not having them actually assigned. You can also use them as layered shaders.
You can control the characteristics of the animation by defining the tangent in and tangent out options of the animation curves (these are generated automaticly and can be overseen in the animation window).
You can find this options down low in the keyframe option window.
Setting this from smooth to linear makes the animation more straight and understandable at the beginning.
If you want a ruff colorchange instead of an gradual process you have to set two keyframes in very short distance (i.e. kf 30=blue / kf 31=red)...
Regards
Tobias
Hi sorry about the late reply. I managed to figure out how to achieve what I was after - I even used the action window.
Thanks for your help on this one! Do you have a email address? I will send you some of my renderings and see what you think!
Cheers -
Manish
hmmm...though i really would like to see the outcome of this, i hesitate to "publish" my mail address. Indeed i am a bit strange regarding those things. This is not ment to offend you!
uhm..isnt there a way to send private messages within the forum?
Kind Regards
Tobias
Hi Tobias,
I have just sent you a private message with containing my email address... have a look and see if this messaging system works??
Cheers -
hmm i did not recognize any message...
send it to kontakt00@digitalform.de...
cheers back
Tobias
