Alias General Discussion
New Member
0 Kudos
Post 1 of 6
Alias Studio Problem Sketching with Paint Symmetry
304 Views, 5 Replies
08-27-2008 07:40 PM
I have encountered a problem using the paint symmetry tool within Alias Studio paint/sketch workflow. When I attempt to use either bilateral or radial symmetry when sketching with any paint brush I experience massive lag.ie. The stroke is drawn onscreen several seconds after I've completed.
I use a wacom cintiq although the same result is encountered when using the mouse as an input device so I do not believe it to be a driver issue related to the tablet. The problem persist regardless of how small I make the canvas; minimum number of layers ect. I have a reasonably high spec. machine, so I do not expect it to be a hardware resource issue. No other applications are running, so it should not be an application conflict. And finally, I've updated the drivers on everything I can think of.
If anyone else has experienced this problem and has found a solution could you please advise. Thanks.
Active Contributor
0 Kudos
Post 2 of 6
Re: Alias Studio Problem Sketching with Paint Symmetry
08-28-2008 09:45 PM in reply to: andrewrumble
what graphic card?
if your on subscription, I would call that in.
Geez, Thats the reason i dont use photoshop and i never have had that issue.
Employee
0 Kudos
Post 3 of 6
09-01-2008 12:01 AM in reply to: andrewrumble
I`ve experienced this with my Toshiba tabletPC, mainly in screen clone mode (using beamer)
Unfortunately, I was not able to reproduce it regularly and I still suspect it is wacom/nvidia issue.
I`ll keep you posted if found anything.
mike
Valued Contributor
0 Kudos
Post 4 of 6
09-23-2008 05:12 AM in reply to: andrewrumble
Rereading the original question, I don't see anything about PhotoShop. How did that become part of the issue?
10 Kudos
Post 5 of 6
10-15-2008 04:02 PM in reply to: andrewrumble
ive seen massive lag too but havent found any ways to fix it yet..
New Member
0 Kudos
Post 6 of 6
10-11-2012 06:19 AM in reply to: CarlFrischmuth
any solution ? I m having the same issue.
