Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Alias 'ink n pen' render
1 REPLY 1
458 Views, 1 Reply
Is there a way with Alias (maybe a shader) that I can render my models to achieve an 'inked' outline look? I know 3DS Max can do it. I want to express all hard edges with a line. Thanks all!
1 REPLY 1
JohnDixon8251
You can use Hidden Line rendering (under Render-Render-Hidden line Render)
You can control the effect with each objects shader (Hidden Line Rendering Perameters in the shader window)
or globally within a section of the Render Globals (at the bottom).
One problem is that it also puts lines between each surface.
