Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Alias Design 2014 Unable to Move Points
4 REPLIES 4
MikahB
722 Views, 4 Replies
Full Disclosure: I am very new to Alias.
I'm reverse engineering a mesh and have projected curves onto it then made an array of Fit Curves to work with.  Before creating surfaces, I am working to tie endpoint CV's to other curves so everything is lined up.
Typically I use Pick Edit > Transform > Move and Curve Snap - works great.  Then, occasionally, it just stops working.  It lets me pick and snap, but when I release the left mouse button, the edit point just snaps back to its original location.  If I close and restart, the operation works fine for a while until the same thing happens again.
Am I unwittingly getting into some state that I'm unaware of or is this possibly a 2014 "feature"?
Mikah Barnett
All Angles Design
Product Design Suite Ultimate 2014
Windows 7 Professional x64
Intel i7-3770k @ 4.5GHz
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
4 REPLIES 4
MikahB
in reply to: MikahB
Think I answered my own question - maybe. If I delete the construction history for Fit Curves that don't want to snap, they seem to work. So, maybe the Transform's I'm trying to do are valid on some but not others depending on whether or not it agrees with the construction history?
Mikah Barnett
All Angles Design
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
ravenzep
in reply to: MikahB
Yes, it is the history that is doing that. You should delete it.
MikahB
in reply to: ravenzep
Thanks Ravenzep - that was indeed it!
Mikah Barnett
All Angles Design
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
ravenzep
in reply to: MikahB
You are welcome 🙂
