Hello everybody!
I am currently encountering a problem with a new Alias AutoStudio 2015 Student Version installation.
I cannot start the program as it is always crashing in splash screen during "constructing menus and shelves".
I am running a mobile system with Windows 8.1 64bit and an AMD Radeon HD 8970M (Catalyst 14.4).
Alias 2014 Automotive worked flawless but now I de-installed the software without any postive effect on my problem with Alias 2015.
Strangely I was able to start and work with Alias 2015 twice, directly after reeinstalling it. But after closing the app the problem accured again. So repairing, reinstalling or deinstalling/ installing had no lasting effects. I also tried to solve the issue by working on the settings for switchable graphics and deleting old 2014 preferences but nothing helped.
Somebody has a clue what is going on?
hello there . me too, a similar problem..
alias studio 2015 crashes on startup splash screen exactly while : constructing menus and sheves
i hope there will be a fix soon
thnx all š
You also had a previous version of Alias installed on your system?
My first guess was that there might be a problem with some preference-files.
I also mentioned that I was able to start the program directly after installing it. After using it once I couldĀ“t start it again until I re-installed it. Then I was able to use it again for one session (without any problems btw)
For me thatĀ“s a hint towards some filesystem problems rather then graphic-driver-related stuff ... but I am just taking a guess ...
Hi all,
I have exactly the same problem with AliasDesign2015 Student Version. I have been running it for about two weeks with a few crashes but today it wonāt open at all and crashes when "constructing menus and shelves".
Here are my tech specs:
MacBook Pro (Retina, 13-inch, Mid 2014)
Processor: 3 GHz Intel Core i7
Memory: 16 GB 1600 MHz DDR3
Graphics: Intel Iris 1536 MB
I have had no previous versions of Alias on this computer.
Anyone know if there is a fix for this?
/L
Hi all, I'm having this same issue on Autotudio 2016 version.
It crashes exactly the same place as everyone else in the thread, constructing menus and shelves
2015 loads up fine.
Specs:
i7 4790K 4.0 Ghz - 4.4 Ghz
Nvidia GTX 980M
16 GB DDR3
Please check it out and see if it solves anything. http://forums.autodesk.com/t5/alias-general-discus
Since I don't use and I don't know MAC, I am affraid I can't provide any tip for you guys. But try to guess where you related Appdata\Autodesk\Roaming is and Delete Alias from there. Should resolve I suppose.
PS: ALWAYS BACK UP YOUR FILES PRIOR DELETE.
HTH, GOOD LUCK.
