Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Access Alias from an external application
5 REPLIES 5
403 Views, 5 Replies
1) Can we get Alias handle from an external application (.exe)?
2) Can Alias be accessed through .NET application?
5 REPLIES 5
TheHangman
Hi Sampathskp
I am not sure if I understood what did you mean clearly...
So, it depends, for instance you install Alias in "A" server with "network license" you still need to have the software installed in another machine anyway.
like my previously job was everything stored on server. (No ideia how this things works to be honest)
But again, if you intend to use it remotly access Alias, I don't think you can.
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
in reply to: TheHangman
Hi aqhead,
   Thanks for your response, Alias and .NET application are on the same machine. My intention is to get the instance of running Alias and load a file(.wire) from .NET code.
Thanks again.
TheHangman
Hi sampathskp
I don't think its directly possible. But, even if you could achieve this. all the work to refine the surface afterwards for class-A either C, it would not be worth the work, don't you think? Concidering opening a file from ICEM Class-A, the impolarity sometime gives a lot of trouble.
So here is the common options for:
Import Options - http://goo.gl/nx9UBE
Export Options - http://goo.gl/ycGEAj
Also check this out.
Code Overview - http://goo.gl/Kx3i0j
Cheers!
Hi aqhead
Just came across yourthread  you seem knolagble about Alias and get back to people, are you on facebook or msg need to ask some tec questions about render settings..
hope you can help out a  newbie
Thx Liz : - )
TheHangman
I am afrad, I am not on Facebook.
But feel free post any query on Autodesk Community and we all will try to help
Regards
