I am completely confused. I drafted the interior curves exactly like the tutorial said. But, which one of the screenshots I included should I use? The first screenshot depicts the build without checking the FLIP option. The second screenshot is what I get when I don't click FLIP and click build . The third screenshot is what appears after I click FLIPand click the BUILD button. I've tried both ways and when I get to the part to create transition surfaces for the handle and drag a pick box around the handle interior draft surfaces, I don't get the ACCEPT box in the lower right-hand corner.
Check the AutoUpdate box in the bottom, then you won't have to click Update every time you change an option.
I'm not sure what you want to do, but try clicking Update or just hitting the Spacebar (same thing).
