Bonjour; est-t'il possible d'enlever ce trait bleu après avoir fait une extension sur extension, cela m'empêche de faire un trou pour la vitre ?
Hello; Is it possible you remove the blue line after an extension of extension, it prevents me from doing a hole to the glass ?
Merci d'avance. 🙂
I can see that you have a span there......
Well, you could remove the span but the shape will not be the same anymore unless you split the surface based on the span.
Here's a video http://sendvid.com/gwevi8bu , hope that it helps
