Move a yellow dot ?
Move a yellow dot ?
12qs1
Move a yellow dot ?
12qs1
Hi, how we can move a yellow dot in axe Manually ?
Cheers
Could you please kindly share with us a screenshot that shows the yellow dot ?
Thank you.
12qs1
Hi, okay.
I see... they are known as CVs... Yes, definitely you can move them.
Use pick CV tool, then simply move them with your 3 button mouse in X. Y or Z direction.
For something more advanced, you can use the Transform CV tool.
Kindly locate these tool by using the Tool Locator under Help if you can't locate them in the palette.
Those are called CVs. 🙂
From the palette, select "pick" - "point type" - "cv" and then transform them any way you like.
Or, hold space bar down and choose the X from the Transform CV quick menu and then a mode of transformation (also located below the display option to the right of the screen, next to the cross section manager tool).
12qs1
Okay, Thank verymuch. Smiley Happy
