Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Latest Updates | New Knowledge Network Articles | Alias
2 REPLIES 2
Azmeera.M
1210 Views, 2 Replies
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Alias?
(List shown in chronological order)
 Subscribe to receive updates for new Alias Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
Azmeera M.
Autodesk Employee
2 REPLIES 2
Azmeera.M
in reply to: Azmeera.M
ARCHIVE
December 2015
How to work with Autodesk Automotive Assets
Wired view of object is too bright in Alias
January - March 2016
How to render via commandline with Autodesk Alias
Perspective camera view is non proportional scaled in Alias
Autodesk Alias 2016 will not start up properly on OSX10.11.x (El Capitan)
April 2016
Autodesk Alias cannot interpret the color map correctly for the first time
Opening wire files in Windows File Explorer will not Launch Alias 2016
Displacement map is not displaying its effect.
In Vector Stlye print mode, locator is not shown
May 2016
Alias Design 2017 Hotfix 1 - The upgrade patch cannot be installed
Alias Surface 2016 not responding while using CV movement during diagnostic Shading
Freeform Blend tool is missing in Alias Design 2017
Shaded objects in Alias are flickering
Missing dxf and dwf import and export options within Alias 2017
June 2016
Alias wire files cannot be opened when the file path contains non-English characters
Can Autodesk Alias open .ginspect format?
Can’t import Adobe Illustrator file
How to remove “P” appearing on a model
July 2016
Alias 2016 cannot start on Mac OS (El Capitan)
Alias often crash after open a certain file
How -g 1 option works with Catia5ToAlias
August - September 2016
Revolve surface of Alias is not a perfect circular object
October - November 2016
Can’t input value for manipulator
The precision Autodesk Direct Conect uses to convert Dassault Systèmes CATIA to Alias
Which file format is the best to transfer from Alias to Inventor?
How to have a multi-radius tube with Tubular offset tool?
Azmeera M.
Autodesk Employee
Azmeera.M
December 2016
Constant crashes while working with Alias Surface 2017
Azmeera M.
Autodesk Employee
