I'm trying to do monorail using 1 generation curve and 1 rail curve. Rail curve is 3 curves attached to one, it seems this is why it doesn't work, is there a way to make it work? Or rails must be natural singe curves without exception?
They must be a single curve.
For ClassA modelling this is just how it is.
For sketch modelling you can join them and create a Multi-Span curve.
Looks like turning on rail rebuild in monorail settings at least made it work, just makes bad geometry with a lot of spans.
Can someone tell me am I doing this in a right way? I'm practicing and I'm trying to model back of a tablet computer. I'm using monorail and modeling 1 quarter of the back first. To model that quarter I'm using 4 generation curves (just copied and put in place), it takes 3 separate monorail actions (monorail with 2 gen. curves) to make it. After that I mirror 2 times to make it full and not just 1 quarter. Is this way normal? It takes quite a bit of time but I guess quality takes time.
I think you could do the whole quater of the back panel with 4 surfaces. One main, two blends and one corner surface.
Or - you could do it with 7 surfaces. If you want more control on the edge - you intersect the rim and the main and add a fillet.
As long as the basic shape is square - it's pretty smooth sailing. 🙂
I'm assuming you mean with 4 surfaces including base planar. I'm adding planar after mirroring, so without it it's only 3 surfaces per quarter as I understand.
