Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
How to Ace K Transition Surfaces?
3 REPLIES 3
paulofern
790 Views, 3 Replies
Hi, Guys....
Please, Is there anybody out there that could help in master k transition corners in G2? How can I fillet that model?
The wire model is at  http://s000.tinyupload.com/?file_id=00851448007744138826
Thanks for You help
3 REPLIES 3
in reply to: paulofern
It really depends on how you want the light to flow. There are at least 4 acceptable solutions.
I think this could be a good one, but it might be tricky. You have to try a few to know which one works best.
duaxiong
This is what I would do:
Notice that I changed the sizes of some of your fillets to allow for more natural transitions.
The small three-sided surface is a trimmed patch.
systembolaget
Another solution, from single span surfaces, particularly when the angle between the two "flaps" is narrower and the two "arms" (fillets) of the K are running into each other in a pointed fashion.
