Hi, Guys....
Please, Is there anybody out there that could help in master k transition corners in G2? How can I fillet that model?
The wire model is at http://s000.tinyupload.com/?file_id=00851448007744138826
Thanks for You help
It really depends on how you want the light to flow. There are at least 4 acceptable solutions.
I think this could be a good one, but it might be tricky. You have to try a few to know which one works best.
This is what I would do:
Notice that I changed the sizes of some of your fillets to allow for more natural transitions.
The small three-sided surface is a trimmed patch.
Another solution, from single span surfaces, particularly when the angle between the two "flaps" is narrower and the two "arms" (fillets) of the K are running into each other in a pointed fashion.
