Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Fail transferring to DETAIL mode
15 REPLIES 15
Message 1 of 16
jaihoyoo
832 Views, 15 Replies
Like written in the subject, I cannot move to DETAIL mode from SCULPT mode.
I can work on multiple tree under SCULPT mode but when it needs to move to DETAIL mode, then there is a specific layer it fails to do the job.
- I can find this small box shape asking me to 'Check conversion'
- Right below corner there pops up with with Conversion error, but then I do not know what to do next.
KR
Jaiho
15 REPLIES 15
Message 2 of 16
Michael-GG
in reply to: jaihoyoo
Hello Jaiho,
if you can't change to Detailing, then your T-Splines can't be converted to Nurbs. This can have several reasons. Problem areas should be shown in red on your model. The conversion error message in the bottom right should also give you more information about why the conversion fails. "Make Uniform" and "Repair Body" with the "AutoRepair" option might be able to help (available under "Utilities"). Also, self intersections of your T-Splines are forbidden. In such cases you need to move your points to fix the shape.
Please let me know if you should still the issues after this. You can also share your model, if you like to, and I can have a look.
Best regards,
GG
Michael G.-G.
Manager Quality Assurance Automotive
Message 3 of 16
jaihoyoo
in reply to: Michael-GG
Hello Michael
I think I have solved my problem with transferring to DETAIL mode.
Instead of fixing my model ( like I told you in earlier message, I do regularly correcting my model with ' Rebuild' and 'Auto Fixing'), I exported my model in .tss format.
And imported this model from new document.
So it worked, all error messages were gone and easy to move on to both DETAIL and RENDER mode without loosing this 'history'
But there were some changes.
1. Lost all names of my layers
2. Canvas , Analysis and other etc layers are gone only surface data is there
But I am happy that i can work with DETAIL mode now.
I have questions here....
1. Can you explain me with this .tss file?
2. Is there a way I can bring my Canvas layer to new file instead of setting new one manually by myself?
3. Can you export to ALIAS with Canvas layer?
Thank you
Jay
Message 4 of 16
Michael-GG
Hi Jay,
it surprises me that exporting/importing via .tss fixes your problem, but well, good for you it works. 🙂
Yes, layer information, analysis and similar get lost, those are not supported in the .tss file format.
1. I think .tss stands for "T-Spline Single". When exporting into this format, each T-Spline body of your model will be written into a single .tss file. There is also a .tsm file format, which I think stands for "T-Spline Multiple", it can store several T-Spline bodies at once. As this is a purely T-Spline specific file format, it doesn't support other file information.
2. You can save an .sf3d file with your canvas, and import it another file (instead of opening it).
3. I thought it would, but looks like I'm wrong. Doesn't seem to work for me, and I also couldn't find any indication in our database that there has been work on this, sorry.
Best regards,
Michael
Michael G.-G.
Message 5 of 16
jaihoyoo
Hi Michael
Thanks for the information.
Your answer to saving Canvas, it worked fine but I need to delete history to import form old file.
Otherwise I can see message telling that Canvas importing is not possible yet if there is timeline(?) in the file.
KR
Jay
Message 6 of 16
Michael-GG
Hi Jay,
I wasn't aware of this restriction, I hope it's still a feasible workflow for you?
Best regards,
GG
Michael G.-G.
Message 7 of 16
jaihoyoo
Hi Michael
Yes it worked fine because it were all just images.
KR
Jay
Message 8 of 16
dahem
Please can somebody help me and excuse me for posting my question here i couldn't find where else !
So the matter is i have speedform and autostudio 2016 student versions , when i export my work from speeform to autostudio , i can not see the hull even when i activate its button and i can not not select or edit anything curves or surfaces !
Message 9 of 16
Michael-GG
in reply to: dahem
Hi Dahem,
you should use the latest version of Speedform (2017), there it works autimatically. In your current version, you must go to "Edit - Ungroup" in Alias first before being able to activate the CV display.
Cheers,
GG
Michael G.-G.
Message 10 of 16
dahem
thanks a lot michael
i have done that but still nothing changed and apparently 2017 can not run on my pc it crashes everytime i try to run it... can you provide me any further help to work on the 2016 version
thanks
Message 11 of 16
Michael-GG
in reply to: dahem
Can you please send a CER (crash report), and let me know the number, so we can fix the crash?
As mentioned above, unstitching in Alias should work. Doesn't it?
EDIT: Sorry, you need to ungroup, then it should work?
Cheers,
GG
Michael G.-G.
Message 12 of 16
jaihoyoo
in reply to: dahem
Hi Dahem
Sorry for the late reply. I was on my vacation for last week.
Well I think you might already have solved the problem with this Hull issue but I would like to leave short information on that in case you havent got the solution yet.
Firstly, I would listen to what Michael has wrote below about installing and working with latest version.
About your invisible Hull, that is because your data has been stitched together and it can be only grabbed when you pick them as an object not as a surfaces. So if that is the case then go to Alias 2017, Surface edit ) Unstitch and select the object. Then you will see massive group of CVs that belongs to each surface then now you can ungroup them, and edit them as a surface.
Hope this has helped your problem.
Kind Regards
Jaiho
Message 13 of 16
dahem
i am back , so i have formatted my pc and installed windows 7 with the
latest drivers etc... i installed autostudio 2017 : autostudio and
speedform are working fine , but when it comes to Vred it crashes whenever
i import a project or even open the armchair or genesis examples.this is
crashing message
[image: Images intégrées 2]
this is the oppening screen.as you can see the scene does not appear and
the views cube is scrumbled
. [image: Images intégrées 1]
This the error repport code :
* CER_137221653*
so installed VRED 2016 and did not want to work too ! this the message it
shows to mee :
[image: Images intégrées 3]*
These are the crash details :
and i did not have any problem with VRED 2016 OR 2017 before , please help
me...
Message 14 of 16
dahem
in reply to: dahem
This are the crashing details :
OS-Version: 6.1.7601 (Service Pack 1) 0x100-0x1
000007FEDD038D13 (ig7icd64): (filename not available): DllMain
000007FEDD031C63 (ig7icd64): (filename not available): DllMain
000007FEDD031531 (ig7icd64): (filename not available): DllMain
000007FEDCFDC6D9 (ig7icd64): (filename not available): DllMain
000007FEDD270FC1 (ig7icd64): (filename not available): DllMain
000007FEEC2B03F2 (vrOpenSGExt): (filename not available): osg::Gradient2Background::clear
000007FEE902BA38 (vrKernel): (filename not available): vrOSGWidget::renderBackgroundOnly
000007FEE9028510 (vrKernel): (filename not available): vrOSGWidget::paintGLI
000007FEE9027C31 (vrKernel): (filename not available): vrOSGWidget::paintGL
000007FEE9027C0C (vrKernel): (filename not available): vrOSGWidget::paintEvent
00000000607F0B56 (QtGui4): (filename not available): QWidget::event
000000006E5B8BA6 (QtOpenGL4): (filename not available): QGLWidget::event
000007FEE9016D8B (vrKernel): (filename not available): vrOSGWidget::event
00000000607B2C66 (QtGui4): (filename not available): QApplicationPrivate::notify_helper
00000000607B2900 (QtGui4): (filename not available): QApplication::notify
000000013F4C76AA (VREDDesign): (filename not available): vrApplication::notify
00000000612AD76C (QtCore4): (filename not available): QCoreApplication::notifyInternal
00000000607F0072 (QtGui4): (filename not available): QWidgetPrivate::drawWidget
0000000060975781 (QtGui4): (filename not available): QWidgetPrivate::repaint_sys
0000000060801576 (QtGui4): (filename not available): QWidgetPrivate::syncBackingStore
00000000607F0EF5 (QtGui4): (filename not available): QWidget::event
00000000612AF343 (QtCore4): (filename not available): QCoreApplicationPrivate::sendPostedEvents
00000000612D2D39 (QtCore4): (filename not available): QEventDispatcherWin32::processEvents
00000000778B9BD1 (USER32): (filename not available): TranslateMessageEx
00000000778B98DA (USER32): (filename not available): TranslateMessage
00000000612D2583 (QtCore4): (filename not available): QEventDispatcherWin32::processEvents
0000000060811155 (QtGui4): (filename not available): QApplicationPrivate::openPopup
00000000612AA6FC (QtCore4): (filename not available): QEventLoop::exec
0000000060BB56C1 (QtGui4): (filename not available): QDialog::exec
000007FEE4F42902 (vrCrashReport): (filename not available): vrCrashReport::sendFiles
000000013F4C50D2 (VREDDesign): (filename not available): __XceptFilter
000000013F4CD83E (VREDDesign): (filename not available): `vredLoop'::`1'::filt$0
000007FEF470F2CB (MSVCR120): (filename not available): _C_specific_handler
00000000779C9D0D (ntdll): (filename not available): RtlDecodePointer
00000000779B91AF (ntdll): (filename not available): RtlUnwindEx
00000000779F1278 (ntdll): (filename not available): KiUserExceptionDispatcher
000007FEE9050C21 (vrKernel): (filename not available): vrOSGWidget::updateAllMGLW
000007FEE8F354A6 (vrKernel): (filename not available): vrController::updateRender
000007FEE8F34057 (vrKernel): (filename not available): vrController::timerLoop
000007FEE8F2E12B (vrKernel): (filename not available): vrController::loop
000000013F4C88BC (VREDDesign): (filename not available): vredLoop
000000013F4CB5EB (VREDDesign): (filename not available): main
000000013F4CC638 (VREDDesign): (filename not available): WinMain
000000013F4CBD4D (VREDDesign): (filename not available): __tmainCRTStartup
000000007779652D (kernel32): (filename not available): BaseThreadInitThunk
00000000779CC521 (ntdll): (filename not available): RtlUserThreadStart
Message 15 of 16
Michael-GG
in reply to: dahem
Hello Dahem,
I think it would be better to post this problem in the VRED part of the forum:
http://forums.autodesk.com/t5/vred-forum/bd-p/2057
I can't really help here. By the way, I don't see the pictures you are trying to insert. Do you see them?
Sorry,
GG
Michael G.-G.
Message 16 of 16
dahem
i can not see them too here they are linked bellow
Thanks anyway
Greetings
