Cutting object using a surface-need help
03:50 PM
Hi there! I'm new to using Autodesk software, previously used Rhino. I'm interested in making a 3D-printable widebody kit for a scale model car, such as this Ferrari:
And turning it into something like this:
I need to have the inside surface of the fenders sit flush with the side of the car, if you can see what I mean. Basically I need the inside surface of each fender to be identical with the side of the car. Is there a tool in Alias which I can use to copy a surface from an existing object and use it to cut out a section of another object, so that the body kit I want to make will sit flush with the side of the model car?
