Solved by haedicu. Go to Solution.
Hello bjur,
I understand that when you have a shear plate on a main beam, you want to have a symbol in detail drawings which shows on which side of the shear plate should be placed the secondary beam.
It is not possibile to do that automatically with current options.
Sorry for that.
I will keep this for feature requests list.
Emy
Advance Steel creates a punch mark in the upper area of the shear plate. You can see it in model as a green line. This is also in the nc-file of the plate and depending on the single part detail style you are using, this point is also shown. See pictures below and let me know, if this is not, what you expect.
best regards
Udo
OK, I see, you meant the assembly drawing, not the single part detail. Here is what i get detailed, when I use an US drawing style for beams:
The label is placed to the punch mark I've mentioned in my previous mail. It can be customized to another label/text if required. I hope, this works for you.
best regards
Udo
I'm sorry, but explaining this with text is not so easy. That's why I've created a short video showing the procedure for an example. Sorry for my English - I'm not a native speaker. - http://youtu.be/fE61K43pk9E
The video shows the modification in drawing style manager.
When you've done this one time, it is saved in your Advance Steel installation and you can use it for each model again and again. If you want to share the modification with others, you have to share the AstorAddIn.mdb from C:\ProgramData\Autodesk\Advance Steel 2015\User2\Data. You can also copy this file directly to the folder of the next Advance Steel version and use it there too.
best regards
Udo
