"Flying" Cut symbol
"Flying" Cut symbol
lk
"Flying" Cut symbol
lk
I have following problem. When I move cut symbol manually and then update the model, cut symbol is moved in strange position. You can see it in attached screencast:
Have you observed that in your AS 2016?
Leszek K
roman_stuber
Hello
Sometimes i have the same Problem. A solution for this Problem woud help to save a lot of Time...
Roman
I have had this problem.
I don't know the cause, but I have a solution.
I have found that trying to move it back into position via the grips will not work, you must select it and then use the AutoCAD move command to move it. This seems to work, and you can use the "from" osnap modifier to easily get it in line with it's partner cut symbol.
lk
Good solution, thanks. It is interesting that if you use undo commean and update the detail once agein the cut sybol is ok. However that method is not good for large models, yours is better.
Leszek K
