in our drawing creations....paperspace, prototype, titleblock, not sure what AS calls them. We have no problems at all creating 'cut' details using the 'create view/section' buuton, but just can't figure out how to create a plan view detail as simple as creating a cut view detail. It has to simple....right???
I've done these heaps of times. You select the icon you have shown, then click the view you want to create the view from. Then select how wide its going to be, and how deep (from memory), then it will ask if you want to use the same scale, then it'll draw the new view.
@TomislavGolubovic Thanks for the reply. Which view are you choosing from the 100's of choices. We have tried numerous and have only been able to generate cuts or sections....Is it possible for you to post a 2 or 3 minute screencast to demostrate, I sure a lot of users would be extremely thankful.
