2 questions:
1/ When i insert a label on my "Anchor Plan" how can I insert the Assembly Mark (F5) instead of the Plate ID.
2/ In the properites you have a view depth (z-viewport) that you can set. Is the front the distance you set below the UCS and the rear distance below the UCS? And there should be holes punched in the top of each plate so why are'nt they being displayed if I have "show hidden lines" tricked. Even untick, it does check my outcome.
1 when you press insert lable button pay attention to command line - you must enter some key to get access to adjust lable text (just don`t know what button it is in english version). then you must adjust lable text for plates, anchors etc.make sure you activate profile you use (default or user) right click on desired and select make active
2 probably there is no type of presentation for holes in drowing style you use
just double clik on the label to bring up the advance properts ( or left clik / rite clik / adavnce properts ) then clik the first pull down menu and change it to part no asembily
see pic
as for part 2
front is like going + z
and bacdk - z
but with most drawing style if the drawing is only off one part say base plates changeing thows setings wont show any more parts
ga drawing style's u can change thows seting to get more of the model on the drawing but ga are kinda bad thay dont update properly , that all ways have parts mising
your hoils not being shown in drawing im thinking u may have chocen the wrong drawing style , i know sum ga's dont show bolts / hoils sum uther style that show a lot of the model may all so not show bolts
wot drawing style did u use maybe triy drwaing style / ga-plan / base detail (pik box or ucs) i find pik box esey to use
