When create a drawing the sheet contains the Autodesk logo in the page header. Can I change this with my own company logo ?
When detailing, Advance Steel uses a prototype stored as a dwg file on the disk, in the following folder : C:\ProgramData\Autodesk\Advance Steel 2015\Shared\Support\Prototypes.
You can open those drawing files with Advance Steel and edit the header with the AutoCAD block edit commands.
Here's a really informative video on customizing prototypes:
Customize Prototypes via Youtube
Hello Heiko,
Do you have any videos available of DS Customization ? If not are your team able to create some for us ?
Hi Werner,
sorry, not that I'm aware of. Maybe others in the forum have an idea?
Object representation is relatively simple to update. Dimension requests and labelling strategies are a little more complex and is where we are lacking in knowledge.
@ Heiko, apologies for thread derailment.
any one got any guides on editing prototypes in advance cad its a bit difrent then the vide
is dose not reconize teh command ATTSYNC
