Upon editing detail drawings I canot figure out how the hatch command works.
I canot get patterns just solid colors?
Solved by muleman1. Go to Solution.
Hi
I think you need to export to AutoCAD and perform the command there
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
@jla-jtl use the search box for this forum, enter hatch and you will see many post about hatch. It is much tricky than reg autocad to use. maybe even buggy
@jla-jtl another thing is sometimes I see solid hatches because of the hatch scale. sometimes i have to set hatch scale to .01 or .001 or even .0001 to get it to work.
As far as the autocad hatch command and manually adding a hatch
When changing the scale of the hatch doesn't seem to work for you and you're still getting solid colors a technique that works for me everytime to correct the sold color problem is to reset the origin of the hatch to a corner or snap point of the object. You have to be able to highlight the hatch and then right click for the drop down and choose " set origin" As long as you can select the hatch you can change the scale and set the origin.
This will fix your problem in 99% of the cases you'll see.
Regards
Craig
ECMS
