How do we change which prototype the drawing process uses? We would like for the drawing process to use our personalized prototypes. We can see where it appears you can select, but the choice is greyed out / dithered, so you can't choose.....or do we have to modify each drawing process prototype individually...
Solved by wtheron. Go to Solution.
I want to add my own process: All Sp PageFull A3.
I am going to start creating this from All Sp PageFull A2, and change only A2 prototype to A3.
Shold I use Copy or Deep Copy. ? Wich is the diference..?
and what else I have to change to make possible using A3 instead of A2.
Thank you.!
hi,
use Copy. DO NOT USE DEEP COPY.
Deep will make copies from every setting in the copy you make, ik will result in setting with names like "copy from copy"
You will get lost in copied settings.
If you need a new setting make your own name and give it a name that you understand later.
I'm really struggling with this - I'm going round in circles trying to navigate to find where i can change the processes to use my customized prototype with company logo etc.
Could anyone provide me with a step by step guide or perhaps a screencast maybe?
Many thanks !
@_Phil_N are you trying to customize your prototypes or create a custom drawing style or process?
this is a very good youtube on customizing prototype https://www.youtube.com/watch?v=q7BSu8ogBQg&list=PL8TTZL-bHSmVK_9rhHsoGgbqB8UqJtEK9&index=6
customizing drawing styles and process is so extremely difficult I can't even begin to attempt to explain.....we are just beginning to try this
Hi, I've already got some customized prototypes (copies that i made of the originals that i have stored in the prototypes directory) that I use in drawing styles.
It makes sense to use them in drawing processes too, however i can't find where to change prototypes within the drawing process manager and am producing processed drawings with the default AutoDesk logo in the title block, then 'changing prototypes' afterwards in the document manager.
So i guess you could say i'm trying to create a custom drawing process.
Hi all,
First: ALWAYS keep a back up of the standard prototypes as installed.
Then when you make your set of prototypes with your logos etc. REPLACE the as installed ones using the same names. Then all processes will link to your prototypes and you never have to think about editing drawing processes.
If you want different prototypes for different jobs copy the prototypes you want (with the standard names) into the Project folder. E.g. Project model called Proj1.dwg. You have a folder with it called Proj1. Inside that put a folder called Prototypes and put the project specific prototypes in there. At all times the prototype files keep the standard names. Any drawings will always be created with Project Specific Prototypes if they exist, without you changing any settings. If a project specific prototype cannot be found then the drawing defaults back to the master one in the master data folder.
As others have said editing and customising Drawing Processes and Drawig Styles is the deepest and most complex part of the entire system. Not something we expect typical users to do themselves and certainly not without guidance and training. You cannot edit anything in the Advance sections of the structures. That is locked as a back up. You can only edit what is in the User section of the structures. On first install the Advance and User sections are the same. Both should have processes for Single and PageFull (Multi Sheet) on each paper size already defined.
I hope that helps.
Aleck Giles, Structures Consultant, Graitec
Aleck,
I´m dealing with the same thing. I noticed that when a use a customized prototype in a drawing created with Drawing Style Manager, everithing works fine, but when a create a drawing with Drawing Processes (and then apply my prototype), the customizations doesn´t work (for example customized dimension styles).
So, in conclusion, if a want to use a customized prototype i can only do by creating drawings from Drawing Style Manager. This is quite annoying since i can´t use camera views with Drawing Processes.
Thanks in advance.
John Bennett
