Advance Steel gives a rather long name suffex to each printed drawing. See attached file. How can I change this. It adds the text "-ANSI-A Advance Steel" to the end of every printed drawing. Is there a way to change this as we need to delete this from each file created.
Hello Bjur,
The PDF file name is controlled by the plotter settings / configuration.
I suppose you have used the Autodesk "DWG to PDF" plotter to create the PDF files for detail drawings.
In this case, there is an option to include the layout information into the file name.
Please see in attached picture the option I am discussing.
Please let me know if this solves your issue.
Best regards,
Emy
The button you highlighted turns off layers in the created pdf. It doesn't have any thing to do with the Layout.
hi,
use publish, much better and works great.
good luck
Hi Bjur,
You are right, that option is not related to the PDF filename.
So the answer to your question is like this:
I suppose you have used the Autodesk "DWG to PDF.pc3" plotter to create the PDF files for detail drawings.
The filename is automatically created from DWG file name and "Model" or "layout_name" appended at the end.
There is no option to change this behavior when using "DWG to PDF.pc3" plotter.
As workaround, you could rename the PDF file(s) after creation to delete the last part of the filename.
You can use multi-rename tools for that.
Best regards,
Emy
Hello, an old thread ..., how is it now , with the "Autocad general doc.?
// Vilhelm
Hi🙂
There are software that helps with renaming files in bulk.
One of which is a free software you can download for windows 10.
Check out "BRU_setup_3.0.0.1" a Bulk Rename Utility application.
Simply google below for additional information.
"What is BRU setup 3.0.0.1 .exe -Free fixer"
I hope this helps.
Janet
Graitec CANADA
This works great for single sheets. For projects with hundreds of sheets, I was hoping for an automated way to have the file names editable before they printed. I wrote a small program to change the file names after the fact but if there was a way to get this functionality out of the box, I'd be stoked.
