purlin in curved beam
javiervega10
Message 1 of 8
javiervega10
how create purlin aligned in a curved beam? the macro purlins are create linear and not radial
Replies (7)
Message 2 of 8
múinteoir
This cannot be done with the purlin macro, you will need to manually place the purlins
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 3 of 8
javiervega10
ok, thank you jonathan, in the macro truss how I make the web section vertical are radial elements are not vertical?
Message 4 of 8
thank you for explaining. Pls, can you explain how to align the purlins to curved beam manually ?? pls can you provide us with more information about this process for instance (simple tutorial, screenshots ..etc)??
Message 5 of 8
mick-CNF
You can do purlins on a curved beam using the Structure Designer in the PowerPack.
If this information solves your problem please accept as a solution.
Message 6 of 8
the Structure Designer in the PowerPack is no free:(.
how do i get it?
Message 7 of 8
mick-CNF
Through the app store.
https://apps.autodesk.com/ADSTPR/en/Detail/Index?id=2566380103529418561&appLang=en&os=Win64
Message 8 of 8
crydee-AG1
The basic process would be as follows:-
  • Draw one purlin at the apex where the web is vertical and perpendicular to the rafter.
  • Use Polar Array to copy the purlins to required spacing around rafter - set whether or not ot rotate members as they are copied. If you say no Rotate then the web stays vertical. If you say Yes to Rotate the web stays perpendicular to the rafter.
Aleck Giles,
LinkedIn
Autodesk Certified Instructor - Gold
