I have the same model linked in several times into one main model. In each link, I have set to have different worksets visible. When rendering in Revit, the views remain correct. When rendering in A360, all worksets are visible. In the past, this has worked fine with older versions of Revit. It seems as if this started only with Revit 2014. Is there an update for A360 for Revit 2014 that enables me to render my images correctly?
Did you upgrade your Revit 2014 to SP2? we fixed a problem about linked model in SP2. If not, you could find the SP2 installer from here:
Revit 2014 Upgrade Release 2:
Revit Structure 2014 Update Release 2:
Revit Architecture 2014 Update Release 2 :
Revit MEP 2014 Upgrade Release 2:
Revit 2014 LT Upgrade Release 2:
Sally
