Show only
Search instead for
Thanks for the suggestion of adding a button to create folders from the select folder modal UI. This is something that we are already planning on doing and have moved this up higher in priority.
You should hopefully see this feature implemented shortly.
This feature was just implemented and pushed to production. We basically followed your suggestion and added a "Create Folder" button in the Change destionation UI. Here is a screenshot of what it looks like. Note the "New Folder" button below.
