Can we have the ability to change the background colour in the 3D viewer?
Many of our parts seem to be quite close in colour to the viewer background. They would stand out better against a different colour and I would rather change the background than the part so that the part still keeps it's correct colour.
Kenny
Kenny,
You can choose between different background and lighting set-ups by pressing the Settings icon on the toolbar at the bottom of the viewer. There are preset color backgrounds. Do any of these choices help with your issue?
Jay Behr
Not exactly what I was thinking, but a perfect solution none the less.
Many thanks.
I think I am more fimiliar with the 360Drive 3D viewer so hadn't noticed the settings on the 360 viewer.
Thanks again.
Kenny
Any way to pre-select the lighting scheme? I.E. moderator views rendering, selects the `Background and Lighting' profile that works best, and A360 Project automatically uses that profile whenever anyone else views the render (unless they select differently).
Also more along the lines of the original post, is there a way to change the color of the background seperately from the lighting profile? I.e. Light Blue background, with Sharp Highlights lighting? In most of the lighting profile the default material color fades into the background.
Would be nice if the A360 renderer used or allowed to use, the same background that Inventor uses (blue to grey fade).
Rich C.
Hi Rafael,
