Hei
I'm new in A360.
I tried to upload a 2d DWG. ACA 2012 fil to my project.
every thing is ok until it's finished to upload, I can not open/view the fil. on line.
I'm using Google Chrome
Hei Bud Schroeder
Thank you for yor reply!
I have tried many time and different fil.s , 2d dwg, 3d dwg,and rvt.
alle the fils were uploaded and stay there over an hour. Steel nothing happened.
I don't know what to do.
You mentioned that it was ACA, which tends to create a lot of reference files. You may need to do a composite upload. Select the main file first and then all the additional files that need to go with it. It will them give you the option to do a composite upload and select the main file. It will then link them correctly when it uploads. See the attached image.
