Whether you are new to A360 or have been with us all along, if you are a user of A360 and are also using A360 Drive you might have the following questions:
The difference between storing files in an A360 project and A360 Drive
Accessing A360 Drive files from A360:
Copying files from A360 Drive to an A360 project:
Our recommendation for how to manage your data in A360:
Take a look at my attached file. Can i Sync project data? If so how and if not why?
HI Matt,
Thanks for your question regarding syncing your data back to your local computer from the A360 Hub vs. from A360 Drive.
You're right, No, currently this is not possible with A360, it's only available with A360 Drive as the illustration displays.
Regarding the "why" part, primarily it's because the current thought around this topic is that when you're ready to share something, that something you do with as an intentional act vs. an update that happens automatically (via sync) where something might be shared that you didn't want it to.
That all being said, if you'd please post this to our Ideastation linked below, then you'd be able to allow others to vote and comment on the idea as well, so it would be really interesting if we could also see if others support this idea as well.
http://forums.autodesk.com/t5/a360-ideastation/idb-p/206
Thanks, again, really appreciate you taking the time to write in.
Still new to this, but here goes:
I have a small architectural office. Even so, we may have 15 projects going on that have data that in tital is probably closer to 50 gb.
The way I understand it, if 2 people are collaborating, then you have 20 gb availalble. Do you purchase more space?
Mark,
I'm really sorry that i didn't see this sooner,
The answer to your question is yes you can purchase additional storage by purchasing additional "member subscriptions" i.e. 1 member = 10GB pooled with any others as you stated in your initial post where you stated 2 members = 20GB pooled storage.
That is the only way that we have for you to currently bump up your storage capacity at this point, but we are looking at different options for future so that you know as well.
So, from your hub, if you go to your profile picture in the upper right corner, you should see the Subscription Details link at the bottom where you can purchase directly from there, or from your Value Added Reseller as well. FYI if you do have your VAR submit your order be sure that they use the same email address as was used initially so that the new A360 entitlements show up in that persons "manage.autodesk.com" site so they can be assigned out properly.
Please let me know if you have any other questions, as well see the purchase process fully documented here.
