Is A360 only for revit 2015??
How to access the central file in revit once it has been uploaded by a project member??
Can we use A360 as a Revit Server for multiple geographical location projects.
can we acess central model in A360 from Revit 2015...??
Thank you
Regards
Vishal
Vishal,
Yes, that is exactly what the service is designed to allow. Team members across sites and company networks can concurrent author the same set of Revit model(s). Note that currently the solution is only available for subscription in North America, and for use by teams with good bandwidth & low latency to the US East Coast. Over time we intend to support teams across the world.
Our product page is live now, so check that out first. And if you have specific questions, we're glad to help.
Cheers,
Kyle
Hi Kyle,
Does A360 perform host and accelerator roles with RevitServers so the one user with a RevitServer in one office can concurrently edit and author a revit model with another office that does not have revit server but does subscribe to A360. Also is A360 the same as Autodesk 360?
Good questions, here's some answers:
-Kyle
I wanted to revisit this question to see if anything has changed.
Can A360 Team host a Revit central file that can be worked on simultaneously from separate geographical locations? Will it sync properly?
I know that A360 Collaboration for Revit is able to perform this task. I am wanting to know if A360 Team can also do this at a lower level.
Seth,
The base A360 Team product has no capability to carry out Cloud Worksharing on Revit models. Cloud Worksharing is the primary differentiation for the C4R product, which also contains A360 Team. We have no plans to make Cloud Worksharing part of the base A360 product.
-Kyle
