A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Is there a limit on .nwc file size?
1 REPLY 1
willemcreffier
275 Views, 1 Reply
I can easily watch large (7Mb) .dwf files on A360, using a 2014 i Pad Air (version 8.1.2 12B440)
If I watch the same content as a .nwc file (would result in a 12 Mb file), A 360 loads the file, but on the very moment you think you can start watching, A 360 crashes.
Or is it an issue about hardware?
Kind regards,
Willem
1 REPLY 1
Hi Willem,
Thanks for sending in your question to the team. Are you able to upload this Navisworks file to A360 and view it there?
Can you also try creating a public share for the file with download enabled and then share that with us.  You can use the megaphone in the lower right hand corner to send us the link, that way it will not be posted publicly.
Thanks for getting us more details and for sharing the file with us.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Autodesk Beta Programs!
Tags (3)
